Weird text alignment when used with expressions
I have a 100 comps that are reading text from an external document via an expression. I set them all to be justified to the right, and they sort of are, but I’m getting a weird break on the second line, the first one extends all to the border of my text cage, but the others are noticeably flushed to the right, I tried modifying the text cage and it doesn’t do anything, in fact, the cage proportions are very different when the expression is enabled than when it isn’t.
Any help?
Thanks.
