Activity Forums Maxon Cinema 4D Weird SweepNurbs Problem
  • Weird SweepNurbs Problem
    Posted by Tayo Onabule on September 7, 2013 at 8:38 pm
    So i designed a logo in Illustrator, and brought it into 4D, but i’ve got this weird problem on one of the B sweep nurbs. I’m using the sweep nurbs because i wanted to animate end/start growth.
    Here’s an example of the problem, there is a spike between the 2 curves of the B that shouldn’t be there
    6485_dbc4d.c4d.zip
    Tayo Onabule
    LightStorm Visuals
    https://lightstormvisuals.site90.net
    Brian Jones replied 13 years ago 2 Members · 1 Reply
  • Brian Jones
    September 7, 2013 at 9:03 pm
    you can’t sweep along a spline with the kind of acute angle in it like the ‘B’ and not have the sweep double on itself in a (usually) messy way. You should either bring in a spline from Illustrator with the full shape you need and put it in an Extrude or use a rail spline in the sweep.
    6486_dbc4drailextrude.c4d.zip
