Activity › Forums › Apple Final Cut Pro Legacy › Weird renders in FCP
  • Jordi J recort
    January 19, 2008 at 12:35 am
    I have to confirm that the trick with the plug-in to force render is not working…for us.
    we will let a project exporting to Uncompressed 8 bit HD..and check.
    Jordi J. Recort
    Composer & Editor
  • Jeremy Garchow
    January 19, 2008 at 2:13 am
    Bummer, Jordi. I am sorry.
    I’d export to 10bit though if you are working in ProRes.
    Jeremy
  • Jim Dodson
    January 19, 2008 at 2:26 am
    Jeremy did you mean to say:
    I’d export to 10bit though if you are working in ProRes HQ.
    It’s my understanding (not by any means certain about this) that ProRes (non-HQ) is 8 bit.
    Jim Dodson
    8 Core Intel — Mac – OSX
  • Jeremy Garchow
    January 19, 2008 at 2:37 am
    Both flavors of ProRes are 10bit.
  • Jim Dodson
    January 20, 2008 at 4:44 am
    Good to know!
    Thank you!!
    One other update to the export workaround:
    I encountered the “bad render” problem (again) (FCP ignores Basic Motion etc) when I tried using Export a QuickTime Movie — but then it worked when I used “Export Using QuickTime Conversion”….
    Jim Dodson
  • Jordi J recort
    January 20, 2008 at 2:36 pm
    This also happened to us.. when we was exporting to ProRes (current settings)
    but if you force a completely new render in Uncompressed or DVCPROHD seems to work.
    Jordi J. Recort
    Composer & Editor
  • Jordi J recort
    January 20, 2008 at 2:42 pm
    no worry Jeremy.. it’s a matter to try and error thing..
    I also tougth I found the workaround just cleaning all the renders with the render manager,, but also was just one flower…sprinng was not yet comming.
    I know that 10 bits is better but,, no space and raid bandwith to handle this… We’re doing simultaneously 3 1 hour programs with around 6 hours of footage each!
    When I came to this project they was working on native HDV.. so capture and post in Prores and final master in 8 but uncompressed it’s still a leap in quality!
    thanks for the apreciaton, anyway!
    and once again, sorry for my bad english!
    Jordi J. Recort
    Composer & Editor
  • Jeremy Garchow
    January 22, 2008 at 5:55 pm
    [Jordi J Recort] “I know that 10 bits is better but,, no space and raid bandwith to handle this…”
    I totally understand. 10bit HD is a monster resource hog.
    Your English is just fine, no need to apologize at all. My Spanish and Catalan are horrendous!
    Jeremy
Page 3 of 3
