Activity Forums VEGAS Pro Weird quirk w BCC Title Studio Text
  • Weird quirk w BCC Title Studio Text
    Posted by Oscar Paquette on August 29, 2022 at 12:56 am
    I don’t understand this but while using some animated text with BCC Title Studio the text disappears mid way through it’s event time length when rendering at 59.94 fps 1080HD. When I render with 29.97 fps it doesn’t get cut off and renders as it’s supposed to.
    Anyone have an idea what could be happening?
    Oscar Paquette replied 4 years ago 3 Members · 4 Replies
  • Graham Bernard
    August 29, 2022 at 2:41 am
    Please supply a ScreenGrab of your Timeline.
  • Oscar Paquette
    August 29, 2022 at 2:48 am
    I’m not sure what this is going to provide but here ya go….
    “How it started” is from BCC Title Studio and disappears half way through the event as stated above.
  • Red-rob Rothkopf
    August 29, 2022 at 10:37 pm
    Hey Oscar,
    I’m honestly not surprised by the behavior you’re describing.
    I’m guessing your Vegas Project Settings are 29.97. When you launched Title Studio it saw the project settings of 29.97 and based the length of its text event/render on that.
    When you then rendered 59fps, that’s double the # of frames that you wanted it to render, but it didn’t know that.
    If you want it to work the way you expect, easiest thing to do is change your project settings in Vegas to a 59fps framerate and then create the Title Studio event… should work the way you want.
    NOW — if you want to know how to get your existing event to by the full length that you want — I don’t have a clue LOL. Try posting on the BorisFX forums and I suspect you’ll get a pretty fast response (I’d be curious to know the answer to since this has snagged me on occassion!).
    🙂 Rob
  • Oscar Paquette
    August 29, 2022 at 10:55 pm
    What actually makes a LOT of sense…. I might have to rest this theory a little bit. Thank you very much!!!
