Activity Forums Adobe After Effects Weird proxy problem – anyone got this?
  • Weird proxy problem – anyone got this?
    Posted by Dino Muhic on April 14, 2009 at 3:33 pm
    Hi guys
    I’m experiencing a quite weird problem with one proxy.
    I got a composition in which I build a 3D cinema using just lights and layers. It is quite a render hog because of all the shadows and lights. I rendered a proxy of it (full resolution PNGs) because I needed to implement it into another composition. It was animated by the way.
    So I placed the cinema comp (proxy enabled) into my main comp.
    Now the problem is, that every time I want to preview the comp in any better than quarter resolution it can’t render it. In the info panel I see “Retrieving Frame” and “Transform & Compositing” flickering meaning it tries to do it but it never comes to an end. It’s the cinema layer that’s causing it, since it renders fine without it even in full resolution.
    I checked the proxy and it’s all looking good.
    Anyone exprienced this already?
    AE CS4
    Win Vista 64bit
    Thank you
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
    Jiri Fiala replied 14 years, 2 months ago 2 Members · 1 Reply
  • Jiri Fiala
    May 20, 2012 at 9:53 am
    Have the same issue in CS6. Did you ever manage to solve this?
