Activity Forums Adobe After Effects Weird Project Saving shananigans…
  • Weird Project Saving shananigans…
    Posted by Bryce Leverich on May 13, 2009 at 3:47 pm
    Hello all,
    I am running into a weird and VERY annoying problem with After Effects CS4. When I save a project file, the file “saves” but when I close the file and open it again, none of my progress has actually been saved. Luckily I have been able to recover via auto-saves, but sometimes I do not have a recent one that has my latest work on it. It’s annoying to setup auto-save every 5 minutes in order to not lose all of my work.
    Has anyone ever run into this problem before? As I am sure you could imagine, it is VERY annoying and with deadlines approaching, it really sucks.
    Also, I am saving the project files to my local drive with my permissions setup correctly.
    Any help would be greatly appreciated.
    Bryce Leverich
    Bryce Leverich replied 17 years, 4 months ago 4 Members · 5 Replies
  • Roland R. kahlenberg
    May 13, 2009 at 4:13 pm
    First off, perform a check on the expiry date of your coffee.
    Kinda silly, but check to ensure that you’re looking into the right folder when you open the file. The File>Recent Projects menu item works well here. Also look into using the incremental save command under the File menu.
    Good Luck
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Bryce Leverich
    May 13, 2009 at 6:33 pm
    Ha! My coffee is a little old, but I do usually use the “Recent Project” option. I have gone as far as saving the project to my desktop, making changes, saving, then re=opening the desktop file… Still doesn’t hold the changes…
    Bryce Leverich
  • Chris Wright
    May 13, 2009 at 9:52 pm
    this is fixed in the 9.01 update. autosaves used to disable normal saves.
  • Todd Kopriva
    May 14, 2009 at 3:10 am
    I can confirm what Chris said. I strongly recommend installing the update.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Bryce Leverich
    May 14, 2009 at 1:49 pm
    I installed it yesterday… We’ll see how it goes today. I am sure this will work (crossing fingers).
    Bryce Leverich
