Activity Forums Adobe Premiere Pro Weird problem with sound in Premiere Pro CC2017
  • Weird problem with sound in Premiere Pro CC2017
    Posted by Ionut Stoica on April 27, 2017 at 6:02 pm
    Hello
    Just did a fresh reinstall for Windows and software.
    When I import any shot with a DJI Osmo in .mov, 25 fps Premiere Pro imports only the video track, like the clip had no audio. That’s not te case for .mov clips shot with a 5DMk3 or with a 70D.
    This is what media info says:
    Generale
    Complete name : E:\DJI_0371.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2014.02 (qt )
    File size : 1,23
    Duration : 7 min 2s
    Overall bit rate : 25,1
    Encoded date : UTC 2017-04-22 22:28:43
    Tagged date : UTC 2017-04-22 22:28:43
    Comment : 0.9.138
    ©gpt : -174.30
    ©gyw : +122.50
    ©grl : +0.00
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Da
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=8
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 7 min 2s
    Bit rate : 25,0
    Width : 1 920pixeli
    Height : 1 080pixeli
    Display aspect ratio : 16:9
    Frame rate : 25,000pfs
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8biti
    Bits/(Pixel*Frame) : 0.482
    Stream size : 1,23 (100%)
    Title : DJI.AVC
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 7 min 2s
    Bit rate : 64,0
    Nominal bit rate : 128
    Channel(s) : 1canal
    Channel positions : Front: C
    Sampling rate : 48,0
    Frame rate : 46,875pfs (1024 spf)
    Stream size : 3,22 (0%)
    Title : DJI.AAC
    I have QuickTime installed and AVID Codecs. I don’t remember needing any special codec for DJI. The file plays perfectly both in Windows Media Player and VLC.
    What might be the problem?
    Peter Garaway replied 9 years, 4 months ago 2 Members · 3 Replies
  • Peter Garaway
    April 27, 2017 at 10:10 pm
    Hi Ionut,
    Can you see if any of these solutions help?
    https://forums.adobe.com/thread/2226408
    This issue affects Premiere Pro CC 2015.3 (versions 10.3 and 10.4) and Premiere Pro CC 2017 (version 11.0).
    Solution 1: Clean Media Cache files
    Delete all the files from “Media Cache” and “Media Cache Files” folders. The location of these folders can be found under Preferences > Media.
    Note: By default, Media Cache Files and the Media Cache Database folders are stored in these locations:
    Mac: /Users//Library/Application Support/Adobe/Common
    Windows: \Users\\AppData\Roaming\Adobe\Common
    Solution 2: Rename the Media Cache folder
    Navigate to the Media Cache location and rename the folders to Media Cache Files_OLD and Media Cache_OLD respectively.
    Solution 3: Move Media Cache to a different location
    Change the location of Media Cache folders to elsewhere on your machine.
    Peter Garaway
    Adobe
    Premiere Pro
  • Ionut Stoica
    April 28, 2017 at 4:57 am
    Thank you for the reply Peter. That seams to half do the trick. I say that because even after deleting the cache in it’s full (deleted the parent folders as well) the problem was still there. So I digged deeper online and after redeleting the cache I renamed the files I wanted to import. It works now, is just that I have to do this every time I reopen an older project.
  • Peter Garaway
    April 28, 2017 at 5:11 am
    Glad to hear it’s working for you and sorry for the hassle.
    Enjoy!
    Peter Garaway
    Adobe
    Premiere Pro
