Activity Forums Apple Final Cut Pro Legacy weird problem when rendering or exporting
  • weird problem when rendering or exporting
    Posted by Itamar Kool on August 8, 2008 at 3:31 pm
    Here’s the set up: I have a sequence with two video layers. The lowest layer is the background; the upper layer is the foreground. The clips in the upper layer are cropped and I distorted them a bit. The sequence shows up OK when it’s not rendered. But when I render it or export it, the upper layer is gone!! I removed all the filters and still the problem persists. Anybody know something?
    Kool En De Anderen
    MAC Pro 8 core/OS 10.4.11/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
    http://www.koolendeanderen.nl
    Itamar Kool replied 17 years, 8 months ago 2 Members · 2 Replies
  • Rafael Amador
    August 10, 2008 at 4:28 am
    Hi Itamar,
    Haven’t you hange, for any chance, the Compositing mode of the layers?
    rafael
    http://www.nagavideo.com
  • Itamar Kool
    August 10, 2008 at 8:35 am
    Hi Rafael,
    Yes I did change the compositing mode a couple of times, But then I changed them back to normal, since they disappeared if I used a different compositing mode. What is the problem here????
    Kool En De Anderen
