Activity Forums Apple Final Cut Pro Legacy Weird problem when I need to make Opacity changes
  • Weird problem when I need to make Opacity changes
    Posted by Bruno Toré on July 20, 2011 at 3:41 pm
    Here is the issue, whenever I have to make opacity changes I get a green preview bar on top of that clip and at the same time the canvas gets also green, greenish or distorts the image or jumps to a diferent frame, its fine once I render the preview but its a pain to have to render the previews all the time.
    I have trashed all the preferences, twice, I played with the RT but I cant figure it out?
    This started 2 projects ago, I got a small gig to edit and the original project file sent to me, came from a pirated version so I just thought that was the reason it was freaking out but I have had that problem ever since.
    I have worked in FCP for years, I have been working on FCP 7 since it came out and i have never had this issue. Any ideas its getting really annoying
    Glenndel Cofi replied 12 years, 6 months ago 3 Members · 3 Replies
  • Chris Tompkins
    July 20, 2011 at 5:18 pm
    Specs & details of footage and sequence are a MUST when posting for help ~ Please.
    Please note that when you change a clip in some way, you may have to render.
    Realtime capabilities depend a lot on the machine’s CPU’s, RAM, Software version, Footage codec, Sequence settings.
    Chris Tompkins
    Video Atlanta LLC
  • Bruno Toré
    July 20, 2011 at 5:47 pm
    The footage is all Apple Pro Rez 444, but as I mentioned before this has been happening for the past 3 projects which were different resolutions including pro res 422.
    Of course it needs rendering, Im not complaining about that being a problem, the problem is that opacity seems to be the only thing confusing the software, other changes like speed still require me to render a preview but i can at least see the unrendered preview without issues such as massive distortion or the actual canvas going completely green.
    This specific project was shot on a 5D, but 4 projects ago i had no issue with 5d footage.
    I cant figure out what is causing it but it doesn’t seem to make a diference the format, codec, camera, alpha I tried all different things and nothing. Seems to have to do with the RT but what could make that change in a couple of weeks. I havent noticed problems with other video softwares. Doesent seem to be a problem with the ram either
    Is it possible something is wrong with the graphics/video card? and is there a way to diagnose that?
    Just for clarity I have been using the same computer for the past couple of months and never had this issue before, I am also the only person with access to the computer.
    Thank you
  • Glenndel Cofi
    February 27, 2014 at 5:41 pm
    Where you ever able to figure out the problem because I’m having the same issue as well
