Activity Forums VEGAS Pro Weird problem (very weird) trying to rendering certain video into MP4.
  • Weird problem (very weird) trying to rendering certain video into MP4.
    Posted by Jf Baez on April 11, 2015 at 6:33 am
    Greetings forum, I have spent almost my whole day trying to get a work-around with this problem, and my last thing I could do is post about it here, just to see if anyone has experienced this before.
    Here I go:
    I have two files, from a recording device called AVERMEDIA (is used to record gameplay from videogames consoles). The files can be edited in vegas without problems, I can edit and render like a walk in the park, no crash, smooth preview playback, etc.
    just for the record, here is the mediainfo properties of those files:
    File 1:
    General
    Complete name : E:\joel’s files\040315-2143.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 459 MiB
    Duration : 3mn 57s
    Overall bit rate mode : Variable
    Overall bit rate : 16.2 Mbps
    Description : AverMedia_c285_001.000.030
    Encoded date : UTC 1970-01-01 00:00:00
    Tagged date : UTC 1970-01-01 00:00:00
    Writing application : Lavf53.3.0
    Comment : Quality_BEST
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L5.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=15
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 3mn 57s
    Bit rate : 16.1 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 59.940 fps
    Minimum frame rate : 59.940 fps
    Maximum frame rate : 60.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.291
    Stream size : 456 MiB (99%)
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 3mn 57s
    Bit rate mode : Variable
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 3.63 MiB (1%)
    ____________________________________________________________________
    File #2:
    General
    Complete name : E:\joel’s files\080415-2223.mp4
    Format : MPEG-4
    Codec ID : isom
    File size : 892 MiB
    Duration : 7mn 54s
    Overall bit rate : 15.8 Mbps
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 7mn 54s
    Source duration : 7mn 54s
    Bit rate : 15.6 Mbps
    Height : 720 pixels
    Minimum frame rate : 59.944 fps
    Maximum frame rate : 60.004 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.283
    Stream size : 884 MiB (99%)
    Source stream size : 884 MiB (99%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 7mn 54s
    Bit rate : 128 Kbps
    Stream size : 7.24 MiB (1%)
    Ok back to the problem, I used Twixtor to generate some slow motion clips, to mix them with the original files in my project, this is the twixtor’s file details with mediainfo:
    General
    Complete name : E:\2015 drift epic video project\slowmo joel footage rdr.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 806 MiB
    Duration : 6mn 46s
    Overall bit rate : 16.6 Mbps
    Encoded date : UTC 2015-04-10 16:06:58
    Tagged date : UTC 2015-04-10 16:06:58
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=3, N=15
    Codec ID : avc1
    Duration : 6mn 46s
    Bit rate : 16.4 Mbps
    Maximum bit rate : 45.0 Mbps
    Height : 720 pixels
    Frame rate mode : Constant
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.298
    Stream size : 796 MiB (99%)
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 6mn 46s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : channel0
    Channel(s)_Original : 2 channels
    Stream size : 9.31 MiB (1%)
    Language : English
    Ok this is the scenario:
    I completed the project, I just needed to render to finish and upload, but what happens? while rendering, the rendering process “stops”at 64%, just exactly where the twixtors clips starts in the timeline.
    I just try several things, my output format is MP4 AVC (Audio: 192 Kbps, 48,000 Hz, 16 Bit, Stereo, AAC
    Video: 59.940 fps, 1280×720 Progressive, YUV, 8 Mbps
    Pixel Aspect Ratio: 1.000)
    I try one pass, 2-pass, changing the bit rate, render using cpu only, usin gpu only, profile high, main,base, with no success. I restarted vegas, I restarted my computer, I used the project as a nested file, and the rendering stopped at the same spot (the counter continues to infinite)
    changing the ram in video preview to 0, didnt work. I try with another format, using lagarith, and i used the sony mfx 422 profile to render, it worked too.
    but this is the weirdest thing of all, when I took the rendered file (MFX) and send him to the time line to re-render into a delivery format (AVC MP4), the rendering just stops in the same spot on my original project.
    With this, I really gave up, this is very weird, I tested my AVC MP4 rendering with an old saved project just to see if I messed the codec and it worked fine (using MTS files from a video camera), it rendered the whole project without problems…
    So I am really confused now, because how is possible to have the same problem even with a rendered video in a new format (MFX 422), this really blew my mind.
    If you want to see more technical data just ask (or screenshots), I am so curious now to see whats going on here. I can send
    Thanks in advance.
    Jf Baez replied 11 years, 5 months ago 2 Members · 3 Replies
  • Graham Bernard
    April 11, 2015 at 8:24 am
    [JF Baez] “So I am really confused now, because how is possible to have the same problem even with a rendered video in a new format (MFX 422), this really blew my mind.”
    I’m guessing you’ve matched your Project to the Media containing the ISOM CODEC – yes? And, as you say this edits and plays well in VP – yes? Then after you render and place back into the Timeline you get grief – yes? Well, here’s me guessing – again – that your combination of your captured ISOM footage clashes with the rendered output to the extent you’re finding.
    My solution would be to pre-render to a Vegas-Friendly, Digital Intermediary and use that for editing. It would appear you can go so far and then when you re-introduce “other” renders back into VP it is choking.
    I did a Google on: Codec ID : isom . Many many issues.
    Grazie
  • Jf Baez
    April 11, 2015 at 6:17 pm
    Ok, in the timeline i get no problems, everything plays smooth, and without crashs,just like a charm.
    I want to try the pre-render option to see, im really curious now to see if there is a workaround or to know the problem, as i said, the clip that stops the rendering is the one i rendered with twixtor (from vp), this is curious because i rendered it in mp4 avc, never had a problem re-using files rendered with vegas.
    I will try pre-rendering but i guess you are talking about shift+M, i wasnt sure this is different from the dinamic ram preview.
    Im on this, i stopped yesterday because i had to sleep but i found audio out of sync, some red clips on the timeline ( i didnt know this) and i fixed them replacing the clips.
    I will google the isom codec too, thanks for the feedback
  • Jf Baez
    April 12, 2015 at 1:16 pm
    UPDATE:
    OK after replacing all the files, deleting all the out of sync clips, and several hours trying to render, I found a work-around.
    In fact, I did the pre-render (shift+M) and it was good, it pre-rendered the whole project flawless. But trying to render into MP4 AVC, the problem still appeared.
    so I rendered it in sections, i always keep an eye where the rendering stopped so i could divide the whole thing in segments.
    I was surprised that after rendering the problematic segment, another problematic segment appeared but as i said, i keep rendering the segments and at the end i just made a new project and put all the segments together there.
    I think this problem was because the ISOM codec.
    Thanks for the feedback i hope this to help someone with the same problem.
