Activity › Forums › Compression Techniques › Weird problem converting QT to FLV
  • Weird problem converting QT to FLV
    Posted by Hinge on May 27, 2008 at 11:54 pm
    Greetings,
    Today I was working on a project that was a 30 second video clip consisting of 2 layers edited in FCP.
    One layer is a video from a client which had been compressed using Sorenson3 Codec at 30 fps. The other layer is just a still overlay.
    I exported the video as an H264 QT movie, and then somebody else tried converting it to Flash using the Flash media encoder/On2V codec. This was done on a PC.
    Every time we make an attempt, the audio is out of sync. I tried to export the video from FCP dozens of ways, but still no solution.
    Any ideas?
    Christopher Deangelus replied 18 years, 4 months ago 3 Members · 4 Replies
  • Daniel Low
    May 28, 2008 at 9:43 am
    Was the exported H.264 clip in sync?
    BTW – using Soresnson 3 as source just plain wrong.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Hinge
    May 28, 2008 at 10:04 am
    Yes, the clip is in sync in every format I export from FCP. The sync is lost when I convert to FLV
  • Daniel Low
    May 28, 2008 at 10:34 am
    What version of the Media Encoder are you using?
    If you are using a version earlier than 1.0.2 then loss of sync is a known issue.
  • Christopher Deangelus
    May 29, 2008 at 6:55 pm
    Are you creating a flash player with the video embedded in the flash project, or are you referencing the .FLV (the actual video file) in the flash player? If you are embedding the FLV inside the .fla (and subsequently the swf player) you will get audio desyncs. Make the .fla (and subsequently the .swf) file reference the .FLV file externally, and your problem should disappear.
