Activity Forums Apple Final Cut Pro Legacy Weird problem capturing 24p Advanced
  • Weird problem capturing 24p Advanced
    Posted by Mario Mendez on October 26, 2006 at 6:25 pm
    I have mini-dv footage shot at 24p advanced. I am attempting to capture using FCP’s easy setup for the 2.3.3.2 pulldown. When I capture a minute test clip it comes in at the correct 23.98 frame rate. But when I attempt to capture the whole hour long tape it come in at 29.97. I’m not getting any errors and even tried starting an entire new project and starting over with the same results. I have taken four test clips from every fifteen minute of footage on the tape. They all come in correct.
    I plan to run the hour long clip through Cinema tools but would rather dig it in direct.
    Anyone have a similar problem and found a solution?
    Thanks. –MM
    Editors save hundreds of Hollywood jobs every week.
    Gary Adcock replied 19 years, 11 months ago 2 Members · 2 Replies
  • Mario Mendez
    October 26, 2006 at 11:03 pm
    Thanks that explains a lot of the problems I’ve been having. Thanks.
  • Gary Adcock
    October 27, 2006 at 10:24 am
    [Dave LaRonde] “If FCP encounters anything of an anomolous nature — the pulldown cadedce changes at the shot change, for example — it will not remove the pulldown, and the clip comes in at 29.97.”
    YES it is supposed to.
    would you rather it took out the wrong frames??
    and it does this will all reverse telecine function in all capture settings relating to 24p
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
