Activity Forums VEGAS Pro weird problem
  • weird problem
    Posted by Richard Milner on January 29, 2012 at 11:01 pm
    I am using VP10 and I have been using it and doing what I do since last July. The last two times I have used the program I can’t get the same results that I did before.
    What I am doing is at the end of the video I put a picture. Then I drag the fade offset of the picture over on top of the tail end of the video to give it a really cool fade to the picture.
    But now I can’t do that. I don’t know if a switch has been changed to prevent this from happening or what. The only difference that has been done is I install the Vasst CC program and then uninstalled it. I hadn’t used the software since I uninstalled it until recently and it was right after the uninstall that it began to do this.
    Anyone have a clue what I might have done?
    Blessings!
    Richard
    Matt Carlson replied 14 years, 7 months ago 2 Members · 1 Reply
  • Matt Carlson
    January 29, 2012 at 11:17 pm
    More than likely your automatic crossfades option was set to off during the install/uninstall of VASST. CTRL+SHIFT+X will toggle it back on or find the icon (it looks like a pacman going up… usually between the enable snapping icon and the auto ripple icon.)
