Activity Forums Adobe After Effects Weird Problem
  • Hunter Christy
    June 2, 2008 at 11:02 pm
    i’m not sure if this is the issue or not, but i have noticed that on video cards that have an editable openGL menu, you can change the brightness, contrast, etc.
    SO, in theory, if macs have openGL (im a pc) and if the settings are set differently, and if the preview is running through openGL, maybe this is the problem?
    just a theory.
    THE BiG HONKIN’
    “The Defenders Of Stan”-lots of after effects
  • Chris Wright
    June 3, 2008 at 12:50 am
    Your video looks like it might be using opengl wrong.
    Go to edit->preferences->previews> accelerate effects –
    change from opengl to adaptive resolution or check opengl info button which will open up a place to increase your 200 mb or so opengl. If disabling opengl works, either through ae or Display properties->troubleshoot->hardware acceleration
    then you either don’t have enough 3d mem or you might have an old opengl card which doesn’t support ae7. As long as your export footage looks fine, that’s the important thing.
  • John Mclane
    June 3, 2008 at 4:28 pm
    Thanks guys ! I’m going to check this out right now and I’ll tell you what ! Thanks for your time and precious advices !
