Activity Forums Adobe Premiere Pro Weird Premiere CC behavior when saving, opening window, etc (11.0)
  • Weird Premiere CC behavior when saving, opening window, etc (11.0)
    Posted by Bill Hilferty on August 9, 2017 at 6:01 pm
    Hello there, On my PC systems premiere does a weird time wasting thing whenever I open a marker note window, or save the project. See the video below. The project panel seems to ripple through all of the clips or something before an action completes. If I close my open bins and reduce the amount of items taking up space in the project window it is Alot quicker. Anyone know why this is happening and if I can get it to stop?
    https://youtu.be/4GISN2Spn54
    Win 10 64 bit
    16 gigs ram
    gtx 1080
    i7 7700k 4.5 ghz
    Premiere Pro CC 11.0
    Thank you
    Bill Hilferty replied 9 years, 1 month ago 3 Members · 4 Replies
  • Eric Merklein
    August 9, 2017 at 6:47 pm
    Have you checked out RAM to make sure it’s all good? I run at 32 gigs which might help.
    Eric
    Many thanks.
  • Bill Hilferty
    August 10, 2017 at 12:47 am
    I have another windows pc running 64 gb, basically an identical system except a locked processor and gtx 1070 vs 1080. Could if be a graphics card issue?
  • Todd Perchert
    August 10, 2017 at 8:27 pm
    Not sure why it’s happening. Couple things to try.
    Try another keyboard – which if it’s doing it when opening other bins, then I doubt this will help.
    Try blowing out your preferences.
    To restore default preference settings and plug-in cache at the same time, hold down Shift-Alt (Windows) or Shift-Option (Mac OS) while the application is starting. Release the Shift-Alt keys or Shift-Option key when the splash screen appears.
    https://helpx.adobe.com/premiere-pro/using/preferences.html
    Let us know if anything works, or doesn’t.
    Good Luck!
    TC
  • Bill Hilferty
    August 11, 2017 at 12:58 am
    Thanks for the response but none of that helped.. Weird. On my less powerful mac it actually seems to run faster overall… Project loads the 5,000 items in a flash on my macbook pro but it takes up to 3 mins to load them on my PC with better specs. And then that thing in the video. Any other ideas!??
