Activity Forums Adobe After Effects Weird One!
  • Weird One!
    Posted by Tim Smith on May 14, 2012 at 2:18 pm
    Hi All,
    I’m having AAE problems. It was working fine then started doing this all of a sudden. My clip is 59.94fps the comp setttings frame rate is set at 59.94. When I preview it plays in slow mo. If I then go and change the comp settings to 29.97 the the preview looks correct. Have you ever heard of this or know how to fix it? I have restared and issue did not fix it self.
    Tim Smith replied 14 years, 4 months ago 2 Members · 2 Replies
  • David Ghast
    May 14, 2012 at 4:23 pm
    Check your ram render settings (the panel that shows right on the default template) and see what framerate its set to. Also you might be limited if you use spacebar instead of the 0 key on the numpad to render.
  • Tim Smith
    May 14, 2012 at 5:19 pm
    Thanks David, that was it. I didn’t know to check there and it was different that the project settings.
