Activity › Forums › Adobe After Effects › Weird mpeg render
Weird mpeg render
Posted by Frank Van mourik on November 22, 2005 at 8:40 amHi everybody!
I have a problem that i can’ figure out.
I made an animated menu for a DVD in AE (720×576, D1/DV PAL (1,07)) When i render this out it looks like it has bee squeesed out!
What did i do wrong? Has this something to do with ‘Pixel Aspect Ratio? What can I do? Please help!Thnx Frank
Mylenium replied 20 years, 5 months ago 2 Members · 5 Replies -
Mylenium
November 22, 2005 at 9:43 amMmh? Is it squeezed on the DVD or when watching the movie clip? If it’s just the movie clip, than this is perfectly normal. If it’s on the DVD, you may have to check your import option in the authoring program.
Mylenium
[Pour Myl
Frank Van mourik
November 22, 2005 at 10:17 amIt happens when i export in AE. When I check de movier clip it is squeesed? Am i rendering not correctly?
Mylenium
November 22, 2005 at 10:37 amOnce more: How are you checking your clip? Do you transfer it to DVD and watch it on a standalone player, do you preview it inside your DVD authoring program or do you simply play back the clip using Mediaplayer or similar tools? In the latter case it will look squeezed horizontally because MPlayer doesn ot compensate for pixel aspect. It will look okay, once you put it on DVD.
Mylenium
[Pour Myl
Frank Van mourik
November 22, 2005 at 10:57 amOw sorry! Didn’t make my self clear! I render it out and check de the movie in Power DVD. and it looks squeesed (also if i preview in encore) But when i check de movie clip in mediaplayer it looks fine? Just the othere way round as you said? Any ideas?
THNX Frank
Mylenium
November 22, 2005 at 11:37 amMmh, that’s strange. I would assume that somehow the ratio info gets lost. It shouldn’t be a problem in Encore, ‘cos you could force it to interpret it as non-square. Still, very odd.
Mylenium
[Pour Myl
