Activity › Forums › Apple Motion › Weird Motion Text Jump in Final Cut
  • Weird Motion Text Jump in Final Cut
    Posted by Jake Reeves on February 16, 2015 at 4:52 pm
    I’m just starting to teach myself Motion.
    I’m linking to this little clip of the same motion file in a FC sequence. The second being over a slug with a negative filter on it. At the end of the text there is a bit of a jump where the text loses its glow. This doesn’t happen in the first clip. Can someone tell me why this happens and what I can do to fix it, if there is a fix?
    https://vimeo.com/119771592
    Jake Reeves replied 11 years, 7 months ago 2 Members · 2 Replies
  • Robin S. kurz
    February 17, 2015 at 9:59 am
    It looks to me as if you also have an outline or shadow that is disappearing for whatever reason. You’ll want to check those parameters and/or the keyframe editor. And I’d say the reason you’re not seeing it with the first one is simply because the background is black.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Jake Reeves
    February 17, 2015 at 3:17 pm
    Robin,
    That would make sense. I’m looking into that.
