Hey Jack,
hope you have solved the issue by now. If not, what you are experiencing is interlacing. To avoid it, in the project settings, master settings, make sure that “enable interlace processing” is unchecked and that the video format is not set to any resolution with an i (interlace) suffix.
Hope this helps!
