Activity Forums Apple Final Cut Pro Legacy Weird media problems…
  • Weird media problems…
    Posted by Lokidrummer on December 31, 2005 at 7:05 am
    Hi, I had a bunch of greenscreened footage and when i exported it to a .mov onto my external hd it like broke them up into Media,Media-av1,Media-av2,Media-av3. So when i try to import them all (I’m doing this just so i don’t have to deal w/ prerender stuff), anyways so when i import them it will only import the first “media” file and when i try to play it back it is super slow…So is there like a setting or something that will fix all this?
    Tech info: all the media-av#’s are exactly like 2 gigs, i’m using FCP HD, when i exported the first time i put it on an external HD that was formated to like 3 partitions of FAT32. So yea, any help?
    -William
    Frank Pledge replied 20 years, 8 months ago 3 Members · 3 Replies
  • Gunleik Groven
    December 31, 2005 at 11:41 am
    What format is the media in? (DV/HDV/DVCPRO/DVCPRO100/Whatever uncompressed?)
    Gunleik
  • Lokidrummer
    December 31, 2005 at 4:58 pm
    When I pressed export quicktime i clicked on the top little DV thing….like 48mhz audio….anyways when i go and look at the “get info” on it, it says DV/DVC Pro Integer(Big Endian),Timecode. That’s under it’s “more info” and under the “general” it says it’s a “final cut pro movie”. I thought it’s supposed to be a quicktime video…so yea…it’s like those files that i HAVE to have with it are like the video parts of it…cause without them it says it can’t play the first “media” file. So yea, help.
    -Will
  • Frank Pledge
    December 31, 2005 at 10:45 pm
    doesn’t fat32 only support files up to 2 gigs? or have they fixed that?
    if not – there you go
    fp
