Activity › Forums › Adobe Premiere Pro › Weird lines on graphic elements
  • Weird lines on graphic elements
    Posted by Matthew Turner on June 28, 2017 at 9:09 pm
    For some reason, I’m getting some weird banding lines on one of my graphics. If you look at the screenshot or video below you’ll see it happens on the left side of the frame, but not the right side for some reason. The video also shows my timeline in case that is helpful to anyone.
    At first, I had some of the animations nested, so I thought that may have been the issue, but now, as you can see, I removed any nesting.
    These lines show up on the export as well. Does anyone have any insight into this?
    Here is an image: https://imgur.com/Zbvatnb
    And here is a video (banding starts around the 7-second mark): https://youtu.be/WKLaPB3Vy2s
    Specs:
    MacBook Pro (15-inch, 2016)
    2.7 GHz Intel Core i7
    16 GB 2133 MHz LPDDR3
    Radeon Pro 460 4096 MB
    Intel HD Graphics 530 1536 MB
    macOS Sierra 10.12.5
    Premiere Pro CC 2017.1.1
    Camera: Panasonic GH5
    Footage: 4k 29.97fps
    Sequence: 1080 29.97fps
    View post on imgur.com
    Matthew Turner replied 9 years, 2 months ago 3 Members · 3 Replies
  • Joe Barta iv
    July 6, 2017 at 8:32 pm
    In the Sequence Setting, try turning OFF;
    Maximum Bit Depth
    Maximum Render Quality
    Composite in Linear Color
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Stephen Abbott
    July 11, 2017 at 2:28 pm
    Is that layer called ‘blur’ an adjustment layer? I’ve seen them misbehave with all sorts of strange effects, especially when Mercury Playback Engine is set to OpenCL. Try setting it to Metal or CPU-only under File > Project Settings > General…? This might change render speeds, of course 🙂
    Stephen Abbott
  • Matthew Turner
    July 26, 2017 at 3:25 pm
    That layer was actually called “Blue” and was just a color matte. But upon checking my project settings it looks like the renderer was set to Metal. So I turn it to OpenCL (not sure why it wasn’t on there to begin with) and the lines disappeared.
    Also, note that I followed @Joe Barta IV ‘s advice as well which didn’t work at first. But maybe combined with both of these suggestions it worked?
    Thanks all!
