weird lines after letterboxing
Posted by James Hark on November 29, 2015 at 8:23 pmHey again. So I letterboxed my footage. For some reason in this video I’m getting weird lines on the top and bottom of the letterbox. like a distortion of the image. Anyone know what this is?
https://www.youtube.com/watch?v=8GiBiO7-xmA&feature=youtu.be
heres the video uploaded and unlisted on youtube.
John Rofrano replied 10 years, 9 months ago 2 Members · 5 Replies -
John Rofrano
November 29, 2015 at 8:35 pmI don’t see any distortion. How did you letterbox it? You should just change the project dimensions to the aspect ration you want and let YouTube letterbox it for you.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
James Hark
November 29, 2015 at 8:52 pmoh please tell me what the dimensions would be I have been trying to figure out how to letterbox my videos properally for a while 🙁
I use hitfilm cinestyle and turn everything off except letterbox and i reposition with the plugin.
And the distortion is one very thin line that runs at the top of the letter box and at the bottom of the letterbox.
John Rofrano
November 30, 2015 at 12:06 am[James Hark] “oh please tell me what the dimensions would be I have been trying to figure out how to letterbox my videos properally for a while :(“
It’s actually very simple math. What cinema aspect ratio do you want to use: 1.85:1? 2.39:1? What is your source footage? 1080 HD?
~jr
James Hark
November 30, 2015 at 12:44 amsource footage is 1080 hd yes. i want 2.35:1 letter box. and maybe you can check my other forum i posted i got quite frustrated earlier with hitfilm and vegas 🙁
John Rofrano
November 30, 2015 at 1:06 pm[James Hark] “source footage is 1080 hd yes. i want 2.35:1 letter box.”
OK, so here is how the math works: 2.35:1 means that the images has a width 2.35 x wider than the height which is 1. Since your image will never be wider than 1920 you need to solve the equation for height by dividing your width by 2.35:
1920 / 2.35 = 817.02127659574468
That means the height needs to be 817.02 but there’s a problem. Most codecs can only encode dimensions in multiples of 8 and 817 doesn’t divide y 8 evenly (102.1275) but 816 does (816 / 8 = 102).
So you need to set your project width and height to 1920 x 816 with a Pixel Aspect Ratio of 1.0 to get a cinema aspect of 2.35:1. You might want save that as a template for future projects.
Now you can render to 1920 x 1080 and the process of rendering will letterbox your video the right way.
[James Hark] “and maybe you can check my other forum i posted i got quite frustrated earlier with hitfilm and vegas “
I don’t use HitFilm so I’m sorry but I can’t help you there. 🙁
~jr
