Activity Forums Adobe Premiere Pro Weird issues with MTS files in Premiere Pro CC2014
  • Weird issues with MTS files in Premiere Pro CC2014
    Posted by Michael Pella on July 15, 2015 at 4:24 pm
    I have an editor who is working in Premiere Pro CC 2014 and has what appears to be a corrupt project file. She is editing with AVCHD footage that has been imported as a series of MTS files. For some odd reason, PP seems to be combining the video from one file and the audio from another when attempting to edit into a sequence. We’ve checked the original files at the Finder level and they appear to be fine. This only happens after importing into a project. I’m quite confused as to how this might be happening. Any thoughts?
    Bart Cautaerts replied 11 years, 1 month ago 4 Members · 5 Replies
  • Ann Bens
    July 15, 2015 at 6:03 pm
    Clean out the media cache also clean out the folder manually.
    see if that will help.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Bart Cautaerts
    July 15, 2015 at 9:31 pm
    We had the same problem. I think it’s caused by two media-files having the same file-name and referring to the wrong cache-file name. Cleaning the media cache files resolved this (or deleting only the cache file with the same name as the media-file with the problem). It’s only happened with .mts-files, so I think it has something to do with the .mts foldestructure.
  • Steve Brame
    July 16, 2015 at 12:23 am
    If your camera starts anew at 0000.mts when you insert a new card, a project can wind up having several files named ‘0000.mts’, ‘0001.mts’, and so on. What could possibly go wrong?
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Bart Cautaerts
    July 16, 2015 at 1:19 am
    That I don’t know… It has something to do with the generation of the conform/media cache files. We had a lot of (very long) .mts files with similar names (mostly 0000.mts). As soon as I imported new files, some of the old ones in the timeline started to act strange (as in ‘playing audio from other 0000.mts-files). Deleting all the 0000-cache files (.cfa and .pek) and letting the cache files regenerate solved this issue, for a while… Tried to play around with the import settings (generate .xmp-files), but this didn’t solve it either. Worked around it by “render and replace” the audio track, which generated a new audio file.
  • Bart Cautaerts
    July 16, 2015 at 1:22 am
    My best guess would be it is an error in the media cache database, linking the wrong cache file to the wrong media…
