Activity › Forums › VEGAS Pro › Weird “Invisible border” glitch in Vegas 9
  • Weird “Invisible border” glitch in Vegas 9
    Posted by Mike Ryder on June 28, 2013 at 10:12 pm
    So in sony vegas 9, when a move an image/video towards the edge of the video underneath, using the “event pan/crop” button, I can’t seem to move the image to the extreme right/left/up/down of the video. Instead there a appears to be an invisible border/layer above, which covers the image.
    Its not particularly well phrased sorry, but here is a picture showing the problem
    [img]https://i43.tinypic.com/szdjpc.jpg%5B/img%5D
    Link to image: https://i43.tinypic.com/szdjpc.jpg
    John Rofrano replied 13 years, 3 months ago 3 Members · 2 Replies
  • Mike Kujbida
    June 28, 2013 at 10:32 pm
    While you’re in Pan/Crop, right click on the image, select “Match Output Aspect”, resize as desired and then everything will work as expected.
  • John Rofrano
    June 29, 2013 at 10:52 am
    [Mike Kujbida] “While you’re in Pan/Crop, right click on the image, select “Match Output Aspect”, resize as desired and then everything will work as expected.”
    Yea, the clue here is the Pan/Crop window shows a square cropping area and I’m guessing that your video is not square (it’s a rectangle). Match the correct output aspect as Mike suggested and it will behave as you expect.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
