Activity Forums Adobe After Effects Weird filled-in font problem on switch to CS4
  • Weird filled-in font problem on switch to CS4
    Posted by Scott Hulme on March 23, 2009 at 7:31 am
    I have a CS3 project that uses the font Sketch Rockwell throughout (font sample here: https://www.dafont.com/sketch-rockwell.font).
    I just upgraded to CS4, and when I open the old project file and update it to the new version, all the Sketch Rockwell text appears as filled in — that is, lacking any of the voids within each letterform that give it that hand-scribbled look.
    Even if I try to add a new text layer in AE, the font appears the same way. However, in Photoshop or Illustrator, I can use the font as normal with no problems. Any ideas?
    Roland R. kahlenberg replied 17 years, 5 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    March 23, 2009 at 3:58 pm
    AE’s probably defaulted to Stroking the font. Can’t think fo anything else.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
  • Scott Hulme
    March 23, 2009 at 4:38 pm
    Thanks — it wasn’t Stroke, but you sent me in the right direction. Everything had been made Faux Bold. Mystery solved — much appreciated.
    March 23, 2009 at 7:35 pm
    You’re Welcome
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in Asia.
