Activity Forums Adobe Premiere Pro Weird Extra Frame on In-Point Problem
  • Weird Extra Frame on In-Point Problem
    Posted by Alex Kuzelicki on October 6, 2015 at 2:05 am
    Experiencing a strange problem where, when I set an In-Point from the Source window, the actual In-Point of the clip sent to the Timeline is one frame before the one I selected.
    This only seems to happen ‘every now and then’ which makes it even more of a mystery.
    The problem is especially noticeable when editing montage-style projects because you end up with lots of little ‘flash frames’ at the head of edit points. Pretty annoying having to go back and fix them all. And it’s easy to miss one or two of them.
    This weird behaviour has only seemed to come about in the last couple of months. Anyone experienced this before, and/or know how to fix it?
    Thanks in advance,
    ALEX
    Alex Kuzelicki replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
