Activity › Forums › Adobe Encore DVD › Weird Error
  • Sandra Miller
    April 11, 2008 at 4:45 pm
    Hi Joe,
    Thanks for your response. Actually, I was unable to build/burn successfully with the project saved as a new name. I had to rebuild the project from scratch.
    What is this “File Exists” error that others have been getting?
    Thanks for the tip for the media cache files!
    Sandra
  • Joseph M. morgan
    April 11, 2008 at 6:12 pm
    File “File Exists” error happens in similar fashion. You go to burn/transcode, and it churns all the way to the end and then stops with “File Exists” and that’s it.
    Though that’s not the exact error you got, it might be a similar symptom. If deleting the media cache files solves it, then I would suspect it might be the same error, just maybe from slightly different versions of Encore.
    Anyway, glad you got it working.
    Joe
  • Sandra Miller
    April 18, 2008 at 3:37 pm
    Hello,
    I’m posting this here, because I am working on another DVD, with the same content, except that the main video is different. I left a DVD burning overnight, and when I came back to the computer this morning, it was as if someone had come and closed the encore application, and hence my DVD burn was unsuccessful.
    Well, I tried it again today, and after transcoding for 50, Encore closed by itself. No warnings popped up, it just closed.
    What could this be? Anything to do with the error I had earlier? It hasn’t done this before.
    Sandra
Page 2 of 2
