Activity › Forums › Boris FX Particle Illusion › Weird Emitter
Weird Emitter
Posted by Cenk Yartan on December 23, 2006 at 12:34 pmIm trying to make and area emitter but its complicated.
https://img139.imageshack.us/img139/3633/untitled1jl0.jpg
Here is the link of the pic.
I wanna make a line emitter that covers the body and then explode.I think its about super emitters but can u help me.Thanx!
Great Power Needs Great Responsibility…UNLESS YOU HAVENT GOT A PILLUSION!!!!:-D
Cenk Yartan replied 19 years, 9 months ago 2 Members · 9 Replies -
Cenk Yartan
December 23, 2006 at 1:14 pmActually im trying to do this
https://www.youtube.com/watch?v=25DYxES2Gpc
is this Possible?
Andreas Feix
December 24, 2006 at 10:21 amThere seems to be a problem with your youtube link:
when I click on it, it says:
“This video is a duplicate of a previously uploaded video.”
About your problem:
When I’m right, you want to create an effect similar to Elvis Deane’s Video, where he is hit by a laser & then desintegrates (you just want to let it explode 😉 ).
My tip: Look at Elvis’ tutorial on desintegrating people here on Creative Cow:
https://www.creativecow.net/articles/deane_elvis/disintegratePeople/index.htmlHope it helps… if I’m wrong, oops…;D
Eclipse FX
https://www.geocities.com/desperate_minds
YouTube keyword: eclipsefx -
Cenk Yartan
December 24, 2006 at 2:15 pmthank you.But my problem is a little different.Im trying to make an emitter of alicia.The Teleporter Girl From Smallville.and i recognize that it is hard to make because it needs an alpha channel thing and the body-covering line thing.Sorry About youtube.Here.
https://img225.imageshack.us/img225/5986/njkn0070ca7.jpg
https://img225.imageshack.us/img225/5513/njkn0074na9.jpg
https://img150.imageshack.us/img150/1710/njkn0084lc5.jpg
https://img150.imageshack.us/img150/2992/njkn0110au3.jpgor i can try uploading the video.But there’s a problem with youtube i guess.
Cenk Yartan
December 24, 2006 at 3:00 pmFinally I got the video
https://www.youtube.com/watch?v=4YuRjsEvmoY
Andreas Feix
December 25, 2006 at 12:48 pmI think you’d do it the following way:
When I’m right, alicia teleports / desintegrates from the outside to the inside. Therefore you need an emitter that starts teleporting / desintegrating the person on the outside, and then travelling to the inside.
=> I might have a solution to this, but I need to know how you want to deal with the problem of the alpha channel… alright? 🙂
Eclipse FX
Cenk Yartan
December 25, 2006 at 8:25 pmok.i’ll show a way to particles with photoshop.i mean i dont have a green Back ground so i need to fix it with paint.
Cenk Yartan
December 26, 2006 at 2:29 pmok.U didnT understand.I dont have a green background so i need to paint a single frame and make particles appear in a single place.About
disintegrating ,i did it before.I did everything but emmiter.thats the problem.:-?Great Power Needs Great Responsibility…UNLESS YOU HAVENT GOT A PILLUSION!!!!:-D
Andreas Feix
December 26, 2006 at 4:52 pmOh, you mean that you’re looking for a way to generate a particle effect that looks like the alicia teleporting… hmmm I’d propose you to make use of some of those “colour from image” emitters to create some distortions…
about your emitter type => I’d have two possibilities:
in both types you’d have to roto / paint the masks for the desintegration /teleporting + hiding your disappearing parts frame by frame
1. Use an area emitting super emitters + the mask of your image (use the different masks as an animation file)
2. Use a line – super-emitter (doesn’t need to follow the accurate shape), then modify the point positions throughout the animation…
Might sound a bit complicated…:)
Eclipse FX
Cenk Yartan
December 26, 2006 at 5:06 pmYeah.
