Activity › Forums › Apple Final Cut Pro Legacy › Weird Edit to tape aliasing with DVW-M2000 deck
  • Weird Edit to tape aliasing with DVW-M2000 deck
    Posted by Greg Jones on November 2, 2006 at 12:32 pm
    I’ve encountered a weird problem. I’m mastering a 60min program to a Sony DVW-M2000 Digibeta deck through the SDI port. When I hit play on the timeline and record on the deck everything looks normal. If I try to insert edit onto a blacked tape using the ‘edit to tape’ command I get weird aliasing. It almost looks like the field order in wrong. Anyone else experience this?
    Greg S. Jones
    D7,Inc.
    Orlando,Fl.
    John Steventon replied 19 years, 11 months ago 2 Members · 1 Reply
  • John Steventon
    November 2, 2006 at 12:39 pm
    Just a guess, but under the ‘edit to tape’ option under the RT menu, what have you selected? ‘Use playback settings’ or ‘Full Quality’?
    That doesn’t really explain why it’s ok when you just hit play, but not ok when you edit to tape – but that’s the first place I’d check if I was having a similar problem.
    Hope this wasn’t flotsom.
    J
    John
    Success is merely a failiure to imagine more…
    G5 2.7Ghz, 4.5Gb ram, Blackmagic Decklink/multibridge, 5.6Tb Infortrend storage, FCP Studio 5.02, Makie MCU control, Yahama 5.1 surround, JVC DTV multi-format monitor, 2x23inch Apple monitors – and a partirdge on a pear tree.
