Activity › Forums › VEGAS Pro › weird distortions after rendering.
  • weird distortions after rendering.
    Posted by Chris Willoughby on March 18, 2015 at 6:52 am
    Hi I’m rendering out a little film.
    Some of the shots are about 200 MB.
    I rendered out a sequence at the settings: HD 1920×1080-60p.
    I got these weird distortions, like fringes or rings. I took some screen shots to show.
    The distortions are faintly faintly in the source footage, but after rendering are quite severe.
    If anyone could please give me some insight into what’s causing them and how to remove them or reduce them, that would be great. Maybe if I render at
    HD 1920×1080-50p instead it might make a difference.
    Steve Rhoden replied 11 years, 6 months ago 3 Members · 4 Replies
  • Aaron Star
    March 18, 2015 at 6:47 pm
    That is banding, generally due to not having enough steps in 8-bit video to represent the gradient transitions.
    Is the source footage 60P?
    Try rendering in 32-bit FP (video levels) and seeing if that helps. Unless the banding is present in the source footage.
    Could also try playing back in VLC just to compare.
    Could try a different codec with a default profile that matches (=) the project.
    Could try rendering to XDCAM-EX or 422, use VLC to check output, then use Handbreak to render to .mp4.
  • Steve Rhoden
    March 19, 2015 at 12:04 am
    Yep, that is color Banding. If your source footage has it, then
    not much you can do to completely remove it, even if you render
    it in 32bit.
    There is however some plugins that has a Debanding filter that
    can help a little bit, one such plugin i know of is Tiffen DFX 4 OFX
    for Sony Vegas.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Chris Willoughby
    March 20, 2015 at 9:00 am
    Hi Steve Rhoden and Aaron Star,
    I tried to change the properties to 32bit, but it seems I don’t have the option. Maybe because I don’t have Sony Vegas Pro?
    I gave a screen shot of how it looks to me.
    Thanks for your time!
  • Steve Rhoden
    March 23, 2015 at 7:29 am
    Yeah, that’s not the Pro version of Vegas, So there are limitations.
    But as i said, even if you were able to change to 32bit, there may not
    be any difference.
