Activity › Forums › Maxon Cinema 4D › Weird Depth of Field Issue
  • Jim Scott
    February 4, 2018 at 10:28 pm
    It looks like you still have the issue that Adam referenced: using the Standard renderer with an alpha-mapped texture causing the DOF to vanish where the transparency is, namely the Teleport object as I pointed out. Are you using the Physical renderer as he suggested? If you would provide more information, and a clearer question, perhaps someone can help.
  • Tyler Stefan
    February 5, 2018 at 8:55 pm
    I fixed the issue, it was a particle object which caused the depth of field to do that.
  • Jim Scott
    February 5, 2018 at 9:59 pm
    Great.
