Activity › Forums › Adobe After Effects › weird color problem and render crash
  • weird color problem and render crash
    Posted by Marc Nibor on February 21, 2010 at 1:01 pm
    hi,
    i got a 1920 scene. about 120 secs long
    in the scene are 10 panels moving around which show looped videos. the source of the videos is also 1920.
    there is a lot of movement, reflections and motionblur going on.
    once i am about 2 thirds into the scene and most of the panels can be seen at once onscreen, the rendering becomes very slow (this doesn’t concern me) and i get weird color errors. some of the looping videos on the moving panels become just green. (i doeblechecked, the source does not have this error)
    mostly a few frames later the rendering stop with an error. error4 reading frame from file e:\bla\bla\seq_xx.mp4 86::2
    i thought it might be a memory problem, since it only happens later in the scene when most of the panels are on screen at once and the rendering gets very slow.
    i tried a few times rendering again – starting from the frame where the crash occured. but then the green shows up almost immediately and it still crashes.
    it seems to work fine if i put stills on the panels instead of movies.
    any ideas? : )
    win7, 8gigs, 2.4quad, cs4,
    EDIT: i just rendered the scene using stills instead of videos. the rendering was lightning fast without any errors.
    so i am pretty sure it’s a memory problem – but i don’t know how to fix this yet.
    Joey Foreman replied 16 years, 7 months ago 4 Members · 6 Replies
  • David Johnson
    February 21, 2010 at 2:37 pm
    Sounds like a codec issue rather than a RAM issue … although 8Gb isn’t a ton of RAM, it should be enough. Also, if you have OpenGL on, you might try turning it off too.
  • Todd Kopriva
    February 21, 2010 at 4:55 pm
    If the problem is related to the codec used in the source footage item, I recommend transcoding the source to an intermediate format and using that.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Marc Nibor
    February 21, 2010 at 10:21 pm
    Thanks a lot for all the suggestions.
    I guess I’ll go for the reencoding… Dave’s in depth explanation made a lot of sense to me.
    My source material is 1920 AVCHD PAL
    I edited it in Premiere to suit my needs and then encoded it to mp4 which i used later in After Effects which turned out to be a bad idea.
    Can anyone make a recommendation what coded and numbers most likely should work?
  • David Johnson
    February 21, 2010 at 11:30 pm
    I work on Macs and Win machines and prefer those same codecs for AE work on both platforms, though it also depends on your workflow … I sometimes use an Uncompressed codec out of AE when the hefty file sizes are less important to me than avoiding re-rendering in FCP.
    By the way, sorry I didn’t mention the solution (transcoding) when suggesting the issue might be the source codec … figured that was implied.
  • Marc Nibor
    February 21, 2010 at 11:39 pm
    I guess I’ll take the uncompressed road then.
    The clips are not too long. only about 15 secons each
    thanks for your help guys : )
  • Joey Foreman
    February 22, 2010 at 1:03 am
    If you have Render Multiple Frames Simultaneously on, you might try switching it off. I remember it was known to cause rendering errors in CS3. They might have fixed it.
