Activity Forums DVD Authoring Weird Cinemacraft error message, please help!
  • Weird Cinemacraft error message, please help!
    Posted by John Hatcher on October 14, 2009 at 4:41 pm
    Ok, I’ve used Avid and Cinemacraft to make my DVD files for Standard def forever and not too many issues. All of a sudden though, when I export a quicktime ref file, then try to import into CCE SP, I get a weird “GdipLoadImageFromFile failed: 3” message.
    Anyone know what that means?
    I’ve tried changing which sequence I export, only exporting 30 seconds at a time, all sorts of things and I keep getting it.
    J
    John Hatcher replied 16 years, 10 months ago 2 Members · 2 Replies
  • Roman Melekh
    October 14, 2009 at 10:11 pm
    what codec you have used for your avid’s video?
  • John Hatcher
    October 14, 2009 at 10:28 pm
    Hi Roman,
    I just exported using the Avid template for QT Ref, and unchecked the “Use Avid Codec”. I fixed it, though. I had to uninstall Quicktime, then re-install it. I suspect that must have been what was causing it.
