Activity Forums Blackmagic Design Weird Capture Problem
  • Weird Capture Problem
    Posted by Jeff Kenton on April 14, 2005 at 2:21 pm
    Hi all
    I have problem where in capture mode I am getting a ghosty vertical bar going through the image on the left hand side of the screen. Any ideas? I have a Declink SP with PMG5 Dual 1.8, ATTO SCSI, Sonnet Temp SATA, 4 disk serial ATA Array, 2 disk SCSI 320 Array, FCP HD, Sony UVW-1200, etc.
    Jeff
    Paul Provost replied 21 years, 5 months ago 2 Members · 1 Reply
  • Paul Provost
    April 14, 2005 at 11:56 pm
    just started getting this too! ghostly bar, left side of screen – scrolls across screen to right in cycles. might have something to do with loss of synch problem found in 4.8 drivers.
    only see it in composite analog out – not sdi out. this sucks!
    OS X 10.3.8 – decklink extreme/4.8 – fcp hd 4.5 – ntsc 10 bit
    only see it in one of two identical systems though…failed DLE card?
