Activity Forums Apple Final Cut Pro Legacy Weird capture issue
  • Weird capture issue
    Posted by Jeremy Sexton on June 16, 2010 at 6:17 pm
    I have a Canon XLH1 going SDI into a Blackmagic Card that I use for capture on a weekly basis. We capture to DVCPROHD 1080i60, because that’s what we use for playback.
    We just recently started having this issue where our final render would start normal and about 5 frames in, it would stretch outwards. Like someone grabbed the sides and pulled them out.
    I know DVCPRO is skinnier than full frame 1080 and the pixel aspect ratio causes it to display correctly, that’s not the issue. It’s almost as if it’s taking a full-frame 1080 video and stretching that out in the same manner so that it’s wider than it should be.
    I fixed this on our final render by checking “Recompress all frames”. When I went and looked at my capture scratch, it is having the same problem. I’ve never encountered anything like this before.
    Anyone have any ideas? Thanks.
    Jeremy Sexton replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
