Activity › Forums › Apple Final Cut Pro Legacy › Weird, canvas turns white when playing timeline
  • Weird, canvas turns white when playing timeline
    Posted by Suzin Daly on November 22, 2008 at 6:10 pm
    I am working on making a trailer for a short. Everything is playing great. It seemed all of a sudden when I played the time line the audio played but the canvas only showed white. It’s a 3 minute piece. Not using an external hard drive.
    Stuart Smith replied 17 years, 10 months ago 3 Members · 3 Replies
  • Don Greening
    November 22, 2008 at 6:32 pm
    Go to the top of the Canvas window where the 3 drop down menus are located. Click on the right one and put a check mark beside RGB instead of Alpha. You might have hit the keyboard shortcut for Alpha by mistake.
    – Don
  • Suzin Daly
    November 22, 2008 at 6:43 pm
    Good thought, but did check, RGB is checked. Never happend before in
  • Stuart Smith
    November 23, 2008 at 10:20 am
    Never seen this happen in FCP, but if a clip plays back white in QT Pro it generally means you don’t have the required codec installed.
    Although it sounds like the clips were playing back ok at one point in FCP, so that’s probably not the problem.
