Weird brightness shifts on export
This is a weird one…when exporting out an Uncompressed 10bit quicktime out of an Uncompressed 10bit sequence there a shift in the brightness level for about 5 frames BEFORE a cut point, on not all….but multiple cut points in the sequence. The number of frames vary, but has done it across multiple machines and projects. The footage is Uncompressed 10bit….everything seems normal.
HELP!!!!
thanks so much. Ben.
