Activity Forums VEGAS Pro Weird box shows up when using Yellow Cookie Cutter
  • Weird box shows up when using Yellow Cookie Cutter
    Posted by John Lee on July 21, 2015 at 2:04 am
    I make sports highlight videos and I like to pause the video at times and put a spotshadow on a person. I’m sure there are better methods, but what has been working for me is the following.
    I play the clip until the desire spot. Then I cut the clip and save the image. I’ll then reinsert the .png image into the video timeline where I had made the cut in the video. Then I paste the same .png on the video track above so that I have two still images on top of each other. On the top layer, I then go to Video FX, Cookie Cutter, and Yellow Glowing Portrait. After I move the cursor over the .png file, I’ll move/resize the yellow circle around my subject. Has always worked great every time.
    Now I’m seeing something weird. When I move the yellow circle, the image looks fine until I move the yellow circle over the center of the image. There is a rectangular section that appears OVER the circle when I pass through it. When I close out of Video FX, the circle (if it was over this new rectangle) still appears behind it.
    I’ve never seen this before. I don’t think I changed any settings, but it’s weird. What am I doing wrong?
    And is there a better way for me to have a nice visible spotshadow rather than the method I described above?
    Thanks.
    Bob Peterson replied 11 years, 2 months ago 2 Members · 3 Replies
  • John Lee
    July 21, 2015 at 2:46 am
    Sorry, I meant Yellow Glowing Portrait on Cookie Cutter.
  • Bob Peterson
    July 21, 2015 at 2:51 am
    I duplicated what you described in SVP 12. I did not see the phenomenon that you describe. Do you have a transparent area in the png? I’m wondering if something like that could cause what you are seeing.
  • Bob Peterson
    July 21, 2015 at 2:55 am
    I’m having to guess at your settings, but still not seeing a problem.
