Activity Forums Apple Motion Weird behaviour of text transitions
  • Weird behaviour of text transitions
    Posted by Sascha Engel on August 15, 2013 at 10:03 am
    Hallo Everybody,
    I have following issue: I have a text, certain Text style with Glow applied to it. Then I drop a Text behaviour, for example a Glow In one. Unfortunately, there is a weird jump in the way the text appears, right after the Transition is finished. I thought, maybe it’s only in the Canvas and Export it, but it’s the same. The moment the Transition is finished , the Glow suddenly jumps on. So I thought maybe it’s connected to the fact , that I have Glow on the text set to On, but even without there is a weird jump on the end of the transition.
    What can this cause and how to avoid it?
    I have been absent from Motion for a whil, but I never remembered such a problem.
    Thanx.
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Sascha Engel replied 13 years, 1 month ago 2 Members · 2 Replies
  • Sandeep Sajeev
    August 15, 2013 at 5:43 pm
    Are your Text Behaviours and Effects starting at the same point in time? You can expand the Timeline view to check this.
    Sandeep.
  • Sascha Engel
    August 15, 2013 at 6:28 pm
    Yes, Text layer and text behaviour are starting both at frame 0 and all settings in the text as well.
    Sascha Engel
