Activity Forums Avid Media Composer Weird Behavior with Error Message
  • Weird Behavior with Error Message
    Posted by Brian Thomas on June 17, 2021 at 11:32 pm
    We have a large project and everything in the project loads up and plays fine. Whenever we go to close a bin we get this error message DISK_IO_ERROR, filename:msmFMID.pmr and can’t do anything.
    Our workaround is to open the bins in a new project and work from there but I’ve never seen a corrupted project before…is that possible?
    Ann Foo replied 5 years, 3 months ago 2 Members · 1 Reply
  • Ann Foo
    June 21, 2021 at 6:28 pm
    Do you have a networked system, where different computers are accessing the same bin, from different projects, at the same time? Avid has a built in safety mechanism – if multiple users are accessing the same bin, only the first user can save the bin. The second user will only have read only access to the bin. So, try closign the bin in the new project (and any other project the bin is open in) and see if that helps.
    Another option – .pmr is a database file. These corrupt all the time. Try quitting out of avid and deleting the database files. Next time you boot up avid, it should ‘scan’ media and rebuild new database files.
    Good luck!
