Activity Forums Blackmagic Design Weird Audio Issue
  • Weird Audio Issue
    Posted by Jamie Evans on January 29, 2008 at 11:29 am
    G5 Quad, Decklink, FCP 6.0.2, DVW-A500
    I’m outputting a feature to digibeta and I’m getting random audio distortion and drop-outs. I believe the cables to be good. I’m outputting via the “Edit to Tape” function using 4-channel audio embedded in the sdi video. There’s no Embedded audio xlrs for this card, just 2 analog I believe. I even tried monitoring the audio on the deck, it sounds fine coming in, but when I play it back the audio is sometimes crunchy and even dropped out for a few seconds at one place. It seems that the audio is recorded distorted for a few minutes then clean for a few, back and forth. I just updated to the latest decklink driver, 6.2.2. Still no luck.
    any ideas?
    Kristian Lam replied 18 years, 7 months ago 3 Members · 2 Replies
  • Del Chapple
    January 30, 2008 at 10:08 pm
    Sound like a sync issue. Make sure the DBC is on “input ref” and daed patch the input to the BM card..
    del
    you cant hear my inner voice scream… can you..?
  • Kristian Lam
    January 31, 2008 at 6:41 am
    Hi Jamie,
    I would agree with Del. It sounds like a reference issue so check that your deck is set to Input Video as the reference source.
    regards
    Kristian Lam
    Blackmagic Design
