Activity Forums Compression Techniques Weird 2-3 frame brightness shifts in compressor
  • Weird 2-3 frame brightness shifts in compressor
    Posted by Jeremy Belzer-adams on April 27, 2011 at 7:02 pm
    I’ve tried to do some pretty extensive research on this one (ie google and the cow forums) so I apologize if there is an answer, I just haven’t been able to find it.
    I’m experiencing an odd phenomenon that I haven’t noticed before. I have a final color corrected sequence that I’m exporting out of FCP. I export a self-contained quicktime movie, which is 1080i 29.97 ProRes (HQ). I compress an .m2v and an .aif file in compressor and bring these into DVD studio pro where I do the authoring.
    When I watch the final DVD there are several instances where the brightness in a scene drops 2-3 frames before a cut. For example, I have an interview shot, which cuts to a still image. Right before the cut, the brightness shifts on the interview and it becomes momentarily darker.
    I figured this was a compression issue, so I re-compressed and had the same problem, in the same spot. I went back to the quicktime file thinking that maybe the export from FCP had an issue. The file looks perfect in quicktime, so I brought it into compressor again. What I found is that in the compressor viewer I can see this shift, before I even select any compression preset. So it seems like compressor reads a brightness shift in the file that doesn’t actually exist and therefore transcodes it into my DVD, or H.264 or any other kind of compression that I do.
    Has anyone seen this before? I’m pulling my hair out and I’d like to send out my otherwise perfect DVD without this issue.
    Jeremy Belzer-adams replied 15 years, 5 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    April 28, 2011 at 4:13 am
    Haven’t seen it – but have you tried pushing it to compressor via Send to (instead of an external QuickTime file?)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Jeremy Belzer-adams
    April 28, 2011 at 4:32 pm
    No I hadn’t tried that as I have found exporting quicktime movies to be much more reliable. It did seem to solve the problem though, at least before compression. I’m compressing a new file right now and I’ll let you know what happens.
    Thanks for the reply!
