Activity Forums Maxon Cinema 4D Weighting with multiple effectors
  • Weighting with multiple effectors
    Posted by Ben Rollason on October 25, 2010 at 3:43 pm
    Hi Guys,
    I’m trying to get the following set up working… a sine wave created by several overlaid formula effectors, followed by a sound effector…. these are all just used for weighting, then the actual movement is picked up by one of various plain effectors on different cloners.
    My question is that I can only get effectors to overlay in an additive way. For instance if I have a formula effector with 50% weighting and a sound effector with 50% weighting, then the result will be a 50/50 mix of the two, which the plain effector picks up.
    What I’d really like to do is get something multiplicative working…. for instance the results of the added results of the formula effectors are multiplied by the output from the sound effector… so when there’s silence, there’s no sine wave, when there’s lots of sound, there’s a big sine wave.
    Is this possible using just mograph or do I need to find an Xpresso solution?
    Thanks if you can help.
    Ben.
    vfx.benrollason.com
    Ben Rollason replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
