Activity › Forums › Maxon Cinema 4D › Weight Tool R25
  • Weight Tool R25
    Posted by Laura Fischer on October 8, 2023 at 3:12 pm
    Hello friends. I have one question according Weight Tool in Cinema 4D R25.
    After doing the entire rigging process in R25 I had a problem with the weight tool: when I use the weight tool and click on a joint, several color points from that same joint appear on the entire model, instead of having one point of color radiating from the joint as it was in previous versions. This greatly hinders the process. Did I miss something or is there a way to fix it? Thanks.
    Andy Kiernan replied 2 years, 11 months ago 2 Members · 3 Replies
  • Laura Fischer
    October 8, 2023 at 5:45 pm
    I am sending some images so you can understand what is happening. I have 2 images with the R25 issue and 2 images with R21 which has no issue at all. Thanks
  • Laura Fischer
    October 9, 2023 at 5:33 pm
    Sorry, I just realized that it was just a Display problem, I must use Constating Shading to have the weight tool the way I need. Really sorry for this mistake. My best
  • Andy Kiernan
    October 10, 2023 at 7:50 am
    dont apologise! glad you sorted it, its good to see a solution for anyone who comes across this. It had me stumped ill admit!
