Activity Forums Blackmagic Design Webcam issue when using Desktop Video
  • Webcam issue when using Desktop Video
    Posted by Warren James on July 17, 2012 at 3:22 pm
    Hello All,
    I am currently working on a project that involves using a webcam and an Intensity Pro card.
    The webcam I am using is working from the default Windows Webcam driver.
    If I install the webcam before Desktop Video the webcam is fine.
    After installing Desktop Video the frame becomes cropped.
    I have tested this with another webcam that also uses the default driver and the same happens.
    I am using Desktop Video 9.5.3 although I think when I initially saw the problem I was using 9.5.
    The machine I am using is Windows XP.
    Has anyone seen anything similar or have any ideas for a work around.
    Afsheen Aziz replied 14 years, 1 month ago 2 Members · 1 Reply
  • Afsheen Aziz
    July 17, 2012 at 7:08 pm
    searching the rght solution also…
    if i’ll get to know .. will inform you
