  • Posted by Nick Welch on August 19, 2008 at 10:06 pm
    keep getting lines on my video and i’m thinking why it is.
    My process is this:
    1) capture DV and bringinto FCP
    2) Edit, export – 16:9, progressive, best, 25fps,
    3)compress using sorenson squeeze – ON2 VP6 codec 2 pass+ use de-interlace filter
    but i still get lines – now if i create a AVI in premier and export then it seems to be fine…but a MOV out of fcp – i seem to get lines.
    fields for DV – am i right in saying that DV PAL is lower?..but the content is going on the web…all i do know is that it should b progressive.
    anyone has any idea why i’d be really grateful
    best
    Nick
    BBC
    Best Wishes,
    Nick Welch
    Dan Weiler replied 18 years, 1 month ago 3 Members · 2 Replies
  • Ezio Taranto
    August 20, 2008 at 7:09 am
    Have you tried exporting it as an independent clip from FCP and converting it in Quicktime? or convert it through compressor in a different codec? At least then you will have some comparisons.
    I m trying to compress a 7min 30 sec video for web, which is the best codec to get it as small as possible and still retain some quality?
    Ciao,
    Ezio
  • Dan Weiler
    August 20, 2008 at 4:28 pm
    Try exporting using broadband high for quicktime. This works well for me in NTSC.
    Dan Weiler
