Activity Forums Apple Final Cut Pro Legacy Web file format?
  • Web file format?
    Posted by James Rhodimer on February 1, 2008 at 8:19 pm
    anyone know the best way to export 7min of footage for the web. It was shot on a Canon XH A1 high def camera?
    what file format and sizing to fit the wide screen? I need to stay under 100 megs if possible. everything I’ve tried is either too big or squeezes the width inward.
    thanks
    James Rhodimer replied 18 years, 7 months ago 3 Members · 4 Replies
  • Zane Barker
    February 1, 2008 at 10:09 pm
    [James Rhodimer] ” need to stay under 100 megs if possible. everything I’ve tried is either too big or squeezes the width inward. “
    What exactly have you tried, it is hard for us to say anything without knowing what you have tried.
    Don’t let technology get in the way of your creativity!
  • Russell Lasson
    February 1, 2008 at 10:10 pm
    I would use h.264 in compressor. Just create your own settings. Medium quality should be pretty close to the size you need. Then change the frame size to 640×360.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • James Rhodimer
    February 1, 2008 at 10:37 pm
    thanks. I haven’t tried that compressor yet. I’ll give it a whirl and get back to you.
    cheers
    jim
  • James Rhodimer
    February 1, 2008 at 11:10 pm
    works great. thanks Russell. thanks Zane.
