Activity Forums Adobe After Effects Web export: Render queue with Fast start?
  • Web export: Render queue with Fast start?
    Posted by Espen Jakobsen on October 7, 2008 at 9:08 pm
    Hi yall!
    I’m a bit confused about exporting for the web.
    I recently learned that the best way to export stuff from AE is to use the render queue. When I render something for the web I like to use the quicktime movie/H264 codec at half resolution with a compressed header. I read an article about how this is the best way to go when you want your work out on the web:
    https://motionographer.com/2008/05/16/4-web-design-tips-for-motion-graphics-sites/
    But in the render queue I cant fin a way to do this exact render. If I choose quicktime movie with H264 compression I cant find the fast start option, and the audio compression options seem limited compared to what I get in File/Export.
    And if I choose H264 as Format altough I get more options I still dont get the fast start option.
    Help, please?
    Espen Jakobsen, Norway
    Jay Curtis replied 17 years, 11 months ago 2 Members · 4 Replies
  • Espen Jakobsen
    October 7, 2008 at 9:23 pm
    True. I forgot to mention that right now (and probably later too) I need a solution that let me queue lots of separate clips for web quality, so that it could do most of the work when I’m away from my computer, but I don’t know what render setting in the render queue is the best, since the queue don’t have the fast start option.
  • Espen Jakobsen
    October 7, 2008 at 11:42 pm
    Alright! Thanks for letting me know! Until now I’ve actually used File/Export directly from AE. I have a thing or two to learn on the exporting side. What external program would you recommend? Will QT pro do fine?
  • Espen Jakobsen
    October 8, 2008 at 1:04 pm
    Hey! Just wanted to say that the QT method works great and fast! Can’t believe I haven’t used it before, and apologies for the stupid quesion!
  • Jay Curtis
    October 8, 2008 at 10:26 pm
    Another related question: Why are you likely to get a better result from other applications (QT Pro, Sorenson) than from the Adobe “best” way of doing things?
    I can begin to guess, using a rough analogy, that the Adobe way is a swiss army knife, while other, more specialized programs would be more like using a surgeon’s scalpel.
    I know you’ve been doing this for a lot longer than I have. Under what circumstances (or for what tasks) does the Adobe way of doing things coincide with Dave’s way of doing things? Other than web use with the quick start option, when are those roads most likely to diverge?
    In my case, I recently used AE output to “DVD MPeg” setting for building a Encore DVD for use in a live conference-style event, and it worked beautifully. I’ve also worked at a production house that used AE and Sorenson for small, email-able approval copies of commercials.
    What are a couple of things you’re most likely to go “outside Adobe” for, even though it may be a process they claim to already do well?
    Thanks for your time and expertise!
    Jay
    Jay Curtis
