Activity Forums Apple Final Cut Pro Legacy web and aspect ratio stuff
  • web and aspect ratio stuff
    Posted by Eli Mavros on May 4, 2005 at 5:14 am
    You know how when you shoot in DV and then composite in 10bit, you get that line at the top of the frame due to the conversion of 720×480 to 720×486? Well that is all fine and dandy when I am going to tape or DVD, because of the whole action/title safe area, but what do you guys suggest for posting on the internet, since you see everything? I put very small black bars at the top and bottom, but I don’t know if this looks alright, since it isn’t exactly widescreen looking. But I think it is better than the missing lines of resolution just at the top. I I considered scaling up a bit, but don’t know if that is the best method. Any suggestions? I am doing my reel up, and some stuff truely is 720×486 and then some was originally shot on DV.
    Rainer Wirth replied 21 years, 4 months ago 2 Members · 1 Reply
  • Rainer Wirth
    May 4, 2005 at 11:21 am
    Set a small black frame around the picture.
    Rainer
