Activity Forums VEGAS Pro Weather Radio Audio
  • Weather Radio Audio
    Posted by John Griffin on August 1, 2011 at 8:57 pm
    Hi all,
    I’m looking for how to change some audio to sound like the voice you would hear on a weather alert radio. Thanks in advance.
    John
    Jay Webb replied 15 years, 1 month ago 3 Members · 5 Replies
  • Jay Webb
    August 1, 2011 at 10:46 pm
    It’s quite possible that whatever audio editor you are using already has some sort of a pre-set that will get you close to the sound of one of those weather radios.
    At any rate, what you are trying to replicate is the “cheap speaker” sound of those radios. Am I correct?
    Use a COPY of your original audio to do this…
    I’m sure there are several methods to do it, but what I’d suggest you try initially is (either through EQ or a High Pass Filter) get rid of all the low frequency information, then boost the mids just a little and apply a hard limiter. Then boost amplitude a good bit (normalize if you’re in an audio editing program) and even if the audio ends up distorting, that will just add to the illusion.
    You’ll have to mess around with the settings of these filters. I can’t give exact specifics.
    I hope that helps! Let us know.
    Jay Webb
    jay@voiceofjaywebb.com
    http://www.voiceofjaywebb.com
  • John Griffin
    August 1, 2011 at 11:47 pm
    Thanks Jay. I am doing this all in Sony Vegas Pro. I will give it a try later tonight.
  • Jeff Schroeder
    August 2, 2011 at 2:09 am
    I think the track eq has a preset for radio or telephone.
    Jeff
    http://www.narrowroadmedia.com
  • John Griffin
    August 2, 2011 at 3:02 am
    Ended up using the Resonate Filter and doing some tweaking.
    John
  • Jay Webb
    August 2, 2011 at 11:58 am
    Good deal, John. I’m glad you found something that would work. I’m not familiar with that filter though…I’m wondering what it’s supposed to do.
    Jay Webb
